RiFAst 600F/3.8 Ceramic Glass Full-Carbon Optical Tube [OS-RIFA600CGC]
OS-RIFA600CGC
$100,233.03 USD
0 in stock specialorder
Officina Stellare: Diffraction-limited over a wide and flat field, the RiFast design will push any camera to its limits... and will do it FAST! The extraordinary f/ ratio allows a higher productivity per night, a significant factor for surveys, SN search, asteroid control, and many other fields of modern astronomy.
The central obstruction is about 50%, but still smaller than similar designs, that simply can't compete under any point of view. The visual contrast is very good, thanks also to the special ultra-dark paints we use.
The corrector group is very close to the focal plane, so chromatic aberration is undetectable.
About RiFAst 600F/3.8 Ceramic Glass Full-Carbon Optical Tube [OS-RIFA600CGC]
  • ENTRY PUPIL DIAMETER - 600 mm (24")
  • FOCAL RATIO - F/3.8
  • FOCAL LENGTH - 2280 mm (90")
  • LINEAR OBSTRUCTION - 55%
  • FULLY CORRECTED AND ILLUMINATED FIELD - 80 mm
  • WEIGHT - 105 kg
  • BACK FOCUS EXTRACTION - about 240 mm (9.5")
