Explore Scientific Replacement Cradle Ring Set for 152 mm Carbon Fiber APO [ES-TED152CFCRDL]
ES-TED152CFCRDL
$123.29 USD
Explore Scientific: Replacement cradle ring set with a slotted carry handle and Losmandy style plate for 152mm Carbon Fiber ED APO Telescope. Inside Dimensions = 6.9''; 177mm. This Explore Scientific Replacement Cradle Ring Set will accept any of the Explore Scientific 152 mm aperture Telescope tubes.
If your original Ring Set was damaged, you can use this product as an exact replacement. The hinged ring system separates easily by loosening the over-sized metal thumbscrews, and locks securely back into place once the OTA has been nestled inside the rings. Each extruded aluminum ring set is topped with a slotted carry handle so that it is easy to move your telescope around when it is off the mount. Attach a camera, guide scope, or other accessory to the top of the handle with standard 1/4-20 bolts. Each cradle ring assembly comes with a dovetail plate for quick attachment to a variety of ''Vixen-style'' mounts, including the Twilight Mount from Explore Scientific.
Note: Your product does not include a telescope tube.
About Explore Scientific Replacement Cradle Ring Set for 152 mm Carbon Fiber APO [ES-TED152CFCRDL]
  • Description    Cradle Assembly for Carbon Fiber 152mm Telescope
  • Item Number    TED152CFCRDL
  • Length    7.75"; 197mm
  • Inside Diameter    6.9"; 177mm
    11 in × 11 in × 11 in
    4 lb
