Explore Scientific Replacement Cradle Ring Set for 152 mm Doublet Refractor [ES-DAR152CRDL]
ES-DAR152CRDL
$92.39 USD
Explore Scientific: Replacement cradle ring set with a slotted carry handle for Doublet AR Series 152mm Telescope. Inside Dimensions = 6.1''; 154mm. This Explore Scientific Replacement Cradle Ring Set will accept the Explore Scientific 152 mm Doublet Achromatic Refractor.
If your original Ring Set was damaged, you can use this product as an exact replacement.The hinged ring system separates easily by loosening the over-sized metal thumbscrews, and locks securely back into place once the OTA has been nestled inside the rings. Each extruded aluminum ring set is topped with a slotted carry handle so that it is easy to move your telescope around when it is off the mount. Attach a camera, guide scope, or other accessory to the top of the handle with standard 1/4-20 bolts. Each cradle ring assembly comes with a dovetail plate for quick attachment to a variety of ''Vixen-style'' mounts, including the Twilight Mount from Explore Scientific.
About Explore Scientific Replacement Cradle Ring Set for 152 mm Doublet Refractor [ES-DAR152CRDL]
    9 in × 9 in × 9 in
    3 lb
    9 in × 9 in × 9 in
    3 lb
