Explore Scientific Replacement Cradle Ring Set for 127 mm [ES-TED127CRDL]
If your original Ring Set was damaged, you can use this product as an exact replacement. The hinged ring system separates easily by loosening the over-sized metal thumbscrews, and locks securely back into place once the OTA has been nestled inside the rings. Each extruded aluminum ring set is topped with a slotted carry handle so that it is easy to move your telescope around when it is off the mount. Attach a camera, guide scope, or other accessory to the top of the handle with standard 1/4-20 bolts. Each cradle ring assembly comes with a dovetail plate for quick attachment to a variety of ''Vixen-style'' mounts, including the Twilight Mount from Explore Scientific.
About Explore Scientific Replacement Cradle Ring Set for 127 mm [ES-TED127CRDL]
Explore Scientific: Replacement cradle ring set with a slotted carry handle for Essential Series and Doublet AR 127mm Telescopes. Inside Dimensions = 5.2''; 131mm. This Explore Scientific Replacement Cradle Ring Set will accept any of the Explore Scientific 127 mm aperture Telescope tubes.
- Description Cradle Assembly for White 127mm Telescope
- Item Number TED127CRDL
- Length 8"; 203mm
- Inside Diameter 5.2"; 131mm
$42.00 USD - [S1] USPS Ground Shipping (7-21 days)
Size8 in × 8 in × 8 in
Weight2 lb
