Explore Scientific Replacement Cradle Ring Set for 102 mm Carbon Fiber [ES-TED102CFCRDL]
ES-TED102CFCRDL
$82.09 USD
Explore Scientific: Replacement cradle ring set with a slotted carry handle for Carbon Fiber Series 102mm Telescope. Inside Dimensions = 4.6''; 118mm. This Explore Scientific Replacement Cradle Ring Set will accept the Explore Scientific 102 mm Carbon Fiber telescope tube.
If your original Ring Set was damaged, you can use this product as an exact replacement. Explore Scientific cradle assemblies fit their appointed telescope OTA snuggly, yet protect the delicate surface of the tube. The hinged ring system separates easily by loosening the over-sized metal thumbscrews, and locks securely back into place once the OTA has been nestled inside the rings. Each extruded aluminum ring set is topped with a slotted carry handle so that it is easy to move your telescope around when it is off the mount. Attach a camera, guide scope, or other accessory to the top of the handle with standard 1/4-20 bolts. Each cradle ring assembly comes with a dovetail plate for quick attachment to a variety of ''Vixen-style'' mounts, including the Twilight Mount from Explore Scientific.
.The TED102CFCRDL is 8'' in length and has an inside diameter of 4.65'' - 4.82'' (118.11mm - 122.43mm). If you are considering an Explore Scientific Cradle Assembly as an accessory for another 102 mm telescope, please make sure you check the Outside Diameter (OD) measurements of your scope before you buy.
About Explore Scientific Replacement Cradle Ring Set for 102 mm Carbon Fiber [ES-TED102CFCRDL]
  • Description    Cradle Assembly for Carbon Fiber 102mm Telescope
  • Item Number    TED102CFCRDL
  • Length    8"; 203mm
  • Inside Diameter    4.65" - 4.82" ; 118.11mm - 122.43mm
  • FREE - [S1] International Shipping - contact us for cost (14-28 days)
    8 in × 8 in × 8 in
    2 lb
