Explore Scientific Twilight II Mount with Pier Extension [ES-MAZ-02P]
ES-MAZ-02P
$599.99 USD
Explore Scientific: The TwiLight II Mount is a perfect grab-and-go platform where stability and smoothness counts. Designed to mount one or two telescopes at a time. Works with Explore Scientific, BRESSER, or any telescope that uses the Vixen-style dovetail bracket. Stable and smooth, the TwiLight II Altaz Mount comes with a dual mount head, and a heavy-duty adjustable-height tripod designed for years of rugged use. You can use one or two telescopes simultaneously on the TwiLight II. It also works very well with crowds during astronomy outreach nights, allowing the host astronomer to keep one of the telescopes aimed while the people in line take a look through the other. Of course you can use just one telescope on the TwiLight II. Our largest and heaviest telescope, the DAR152 (six-inch doublet), works fine without counterbalancing the other side. The dual mount head accepts all Explore Scientific telescopes, and most other telescopes that use a Vixen-style dovetail mounting plate.
About Explore Scientific Twilight II Mount with Pier Extension [ES-MAZ-02P]
  • Description    Twilight II Deluxe Dual-Head Altaz Mount w/ Heavy-Duty Field Tripod
  • Item Number    MAZ-02P
  • Tripod fully collapsed no mount head    31.5"
  • Tripod fully collapsed with head    38.5"
  • Tripod fully collapsed with mount head and pier extension (optional)    46"
  • Tripod open, retracted legs, no mount head    26.5"
  • Tripod open, retracted legs with the mount head    34.5" at highest point, 32" to the center of the mounting bracket
  • Tripod open, retracted legs, with mount head and pier extension (optional)    42.5" to highest point, 40" to the center of the mounting bracket
  • Tripod open, legs fully extended, no mount head    42.5"
  • Tripod open, legs fully extended with the mount head    50" at highest point, 47.5" to the center of the mounting bracket.
  • Tripod open, legs fully extended with mount head and pier extension:    58" to highest point, 55.5" to the center of the mounting bracket
  • Weight tripod base    13.6lb; 6.2kg
  • Weight tripod & mount head    22.3lb; 10.1kg
  • Weight tripod, mount head, pier extension    24.6lb; 11.2kg
    34.5 in × 11.5 in × 14 in
    27 lb
