Explore Scientific 120° 9mm [ES-EPWP12009-01]
Specifications:
Focal length 9mm AFOV 120 Degrees EMD 15-layer Multi-Coating 12 elements/8 groups Eye Relief – 13mm Barrel – 2-inch Weight – 3 pounds
About Explore Scientific 120° 9mm [ES-EPWP12009-01]
Explore Scientific: With its apparent field of 120 degrees, this superb eyepiece offers simply the best. Argon Purged waterproof (the N2 purging was upgraded to Ar because of its lower permeability through the polymer seals) As with all Explore Scientific Products, it carries the industry’s most extensive warranty, the STAR program.
Specifications:
- Focal length 9mm AFOV 120 Degrees EMD 15-layer Multi-Coating 12 elements/8 groups
- Eye Relief – 13mm
- Barrel – 2-inch
- Weight – 3 pounds
- Description EXPLORE SCIENTIFIC 120° SERIES 9MM
- Item Number EPWP12009-01
- Focal Length 9mm
- Length 145mm
- Width 60mm
- Weight 21.2oz; 602g
- Barrel Size 2.00”
- Eye Relief 12.5mm
Field Stop Diameter: 15.7mm
$42.00 USD - [S1] USPS Ground Shipping (7-21 days)
Size7 in × 7 in × 6 in
Weight4 lb
