Explore Scientific 100° 30mm - 3" [ES-EPWP10030-01]
ES-EPWP10030-01
$999.99 USD
0 in stock specialorder
Explore Scientific: Scientific eyepiece, 30 mm focal length, 100 ° visible field, 3" (76.2 mm).
In recent years, Explore Scientific eyepieces have built a solid reputation in terms of quality, The eyepiece of Explore is a pleasant and easy experience, the image is beautiful from the first glance.
This eyepiece offers an apparent wide field of 100 °, high level optical quality, surprising light transmission and correctly corrected field planarity ...
Each eyepiece of the 100 ° series is sealed and filled with an inert gas, argon. This process prevents the formation of condensation inside the eyepiece and prevents the entry of dust to maximize the lifetime of the internal coatings. To ensure watertightness, each eyepiece of the 100 ° series is factory tested by immersing it under water for 30 minutes to a depth of one meter.
All 100 ° eyepieces are fully multilayered and the edges are blackened to produce maximum contrast.
The Explore Scientific 100 ° delivers sharp, contrasting images. The apparent field of 100 ° is so wide, that you can keep in sight a celestial object observed in a non-motorized instrument.
The focal length of the 30 ° Scientific Explore Scientific eyepiece predestines it to low magnifications (33x on an optical tube of 1 meter of focal length), making it very suitable for the observation in detail of large nebulae or galaxies, clusters Galaxies or comets, while benefiting from a very wide field of vision.
The 30 mm eye relief is 19 mm: this means that the image remains comfortable up to a distance of 19 mm above the lens, in order to take full advantage of the field of view offered by the eyepiece. This is an important detail for the viewer wearing eyeglasses, which will keep them on the nose.
Finally, it fits into the eyepiece holders with 76.2 mm (3 ") bottles: it should be used on a good eyepiece holder, because the weight of the eyepiece 100 ° 30 mm s' Raises to 2.35 kg.
About Explore Scientific 100° 30mm - 3" [ES-EPWP10030-01]
  • Description    EXPLORE SCIENTIFIC 100° 30MM
  • Item Number    EPWP10030-01
  • Focal Length    30mm
  • Length    200mm
  • Width    107mm
  • Weight    82.9oz; 2353g
  • Barrel Size    3.00”
  • Eye Relief    19mm
  • Field Stop Diameter:    52.2mm
    8 in × 8 in × 7 in
    6 lb
