Explore Scientific 92° Series 17mm [ES-EPWP9217-01]
ES-EPWP9217-01
$549.99 USD
Explore Scientific: Explore Ultra-Wide Eyepieces – Comfort, Quality, Value. The Explore Scientific 92° Series™ eyepieces are hyper-wide class oculars that can transform your visual astronomy experience. You may be startled at the amazingly wide expanse of inky black sky you behold the first time you bring your eye to a 92° Series eyepiece, and after awhile, you may even forget that you have an eyepiece between you and the universe! With an apparent field of view that is close to the maximum for hyper-wide eyepiece design, objects are not only easier to locate, but for non-driven telescopes the object will stay in the field of view for a very long time before any adjustments need to be made.
About Explore Scientific 92° Series 17mm [ES-EPWP9217-01]
  • Description    17mm 92° Series Argon-Purged Waterproof Eyepiece
  • Item Number    EPWP9217-01
  • Focal Length    17mm
  • Length    152mm
  • Width    69.8mm
  • Weight    44.8 oz / 2.8lbs / 1270gms
  • Barrel Size    2.00”
  • Eye Relief    20.02mm
  • Field Stop Diameter:    27.46mm
    7 in × 7 in × 6 in
    4 lb
