Explore Scientific 92° Series 12mm - 2'' [ES-EPWP9212-01]
ES-EPWP9212-01
$549.99 USD
Explore Scientific: Explore Ultra-Wide Eyepieces – Comfort, Quality, Value. The Explore Scientific 92° Series™ eyepieces are hyper-wide class oculars that can transform your visual astronomy experience. You may be startled at the amazingly wide expanse of inky black sky you behold the first time you bring your eye to a 92° Series eyepiece, and after awhile, you may even forget that you have an eyepiece between you and the universe! With an apparent field of view that is close to the maximum for hyper-wide eyepiece design, objects are not only easier to locate, but for non-driven telescopes the object will stay in the field of view for a very long time before any adjustments need to be made.
About Explore Scientific 92° Series 12mm - 2'' [ES-EPWP9212-01]
Description    12mm 92° Series Argon-Purged Waterproof Eyepiece
Item Number    EPWP9212-01
Focal Length    12mm
Height    156.9mm
Width    63.5mm
Weight    36.8oz / 2.3lb / 1043.2gms
Barrel Size    2.00”
Eye Relief    19.92mm
Field Stop Diameter:    19.6mm
    7 in × 7 in × 6 in
    4 lb
