Explore Scientific 82° Series 30mm - 2'' [ES-EPWP8230-01]
The focal length of the Explore Scientific 82 ° 30mm eyepiece predestines it to low magnifications (33x on an optical tube of 1 meter of focal length), making it very suitable for the observation in detail of large nebulae or galaxies, clusters Galaxies or comets, while benefiting from a very wide field of vision.
The 30 mm eye relief is 22 mm: this means that the image remains comfortable up to a distance of 22 mm above the lens, to fully enjoy the field of view offered by the eyepiece. This is an important detail for the viewer wearing eyeglasses, which will keep them on the nose.
About Explore Scientific 82° Series 30mm - 2'' [ES-EPWP8230-01]
Explore Scientific: Scientific eyepiece, focal length 30 mm, apparent field of 82 °, 50.8 mm (2").
- Description 30mm 82° Series Argon-Purged Waterproof Eyepiece
- Item Number EPWP8230-01
- Focal Length 30mm
- Length 131mm
- Width 82mm
- Weight 35.5oz; 1007g
- Barrel Size 2.00”
- Eye Relief 22mm
- Field Stop Diameter: 43mm
Size7 in × 7 in × 6 in
Weight4 lb
