Explore Scientific 82° Series 24mm - 2'' [ES-EPWP8224-01]
ES-EPWP8224-01
$329.99 USD
Explore Scientific: Scientific Eyepiece, 24 mm focal length, 82 ° visible field, 50.8 mm (2 ").
The focal length of the Explore Scientific 82 ° 24mm eyepiece predestines it at low magnifications (42x on an optical tube of 1 meter of focal length), making it very suitable for the observation in detail of large nebulae or galaxies, clusters Galaxies or comets, while benefiting from a very wide field of vision.
The 24 mm eye relief is 17.5 mm: this means that the image remains comfortable up to a distance of 17.5 mm above the lens, in order to take full advantage of the field offered by the lens. ocular. This is an important detail for the viewer wearing eyeglasses, which will keep them on the nose.
About Explore Scientific 82° Series 24mm - 2'' [ES-EPWP8224-01]
Description    24mm 82° Series Argon-Purged Waterproof Eyepiece
Item Number    EPWP8224-01
Focal Length    24mm
Length    110mm
Width    70mm
Weight    24.8oz; 704g
Barrel Size    2.00”
Eye Relief    17.5mm
Field Stop Diameter:    33.5mm
    7 in × 7 in × 6 in
    3 lb
