Explore Scientific 82° Series 18mm - 2'' [ES-EPWP8218-01]
ES-EPWP8218-01
$299.99 USD
2 in stock IN STOCK, usually ships within 48h or less directly from our Canadian warehouse
Explore Scientific: Scientific eyepiece, focal length 18 mm, apparent field of 82 °, 50.8 mm (2 ").
The focal length of the Explore Scientific 82 ° eyepiece of 18 mm predestines it at fairly low magnifications (55x on an optical tube of 1 meter of focal length), making it very versatile for planetary observations (Moon, planets, Sun), and For the search for details in nebulae and galaxies, while keeping a very wide field of vision.
The 18 mm eye relief is 13 mm: this means that the image remains comfortable up to a distance of 13 mm above the lens, in order to take full advantage of the field offered by the eyepiece. This is an important detail for the viewer wearing eyeglasses, which will keep them on the nose.
About Explore Scientific 82° Series 18mm - 2'' [ES-EPWP8218-01]
  • Description    18mm 82° Series Argon-Purged Waterproof Eyepiece
  • Item Number    EPWP8218-01
  • Focal Length    18mm
  • Length    89mm
  • Width    56mm
  • Weight    13.7oz; 390g
  • Barrel Size    2.00”
  • Eye Relief    13mm
  • Field Stop Diameter:    25.3mm
    5 in × 4 in × 4 in
    3 lb
