Explore Scientific 82° Series 14mm - 1.25'' [ES-EPWP8214-01]
The focal length of the Explore Scientific 82 ° eyepiece of 14 mm predestines it at medium magnifications (71x on an optical tube of 1 meter of focal length). It is therefore versatile and suitable for planetary observations (Moon, planets, Sun), double or multiple stars, as well as observation of planetary nebulae and the search for details in nebulae and galaxies.
The 14 mm eye relief is 15.6 mm: this means that the image remains comfortable up to 15.6 mm above the lens, in order to take full advantage of the field offered by the lens. ocular. This is an important detail for the viewer wearing eyeglasses, which will keep them on the nose.
Finally, it fits into the 1.25 "(31.75 mm) eyepiece holders. The inside of the sink is threaded in M28.5 x 0.6 mm to accommodate filters with 31.75 mm (1.25"), Such as interference filters of type OIII, UHC, H-Beta, etc., which serve to enhance the contrast on many nebulae.
About Explore Scientific 82° Series 14mm - 1.25'' [ES-EPWP8214-01]
Explore Scientific: Scientific eyepiece, focal length 14 mm, apparent field 82 °, 31.75 mm (1.25 ").
- Description 14mm 82° Series Argon-Purged Waterproof Eyepiece
- Item Number EPWP8214-01
- Focal Length 14mm
- Length 83mm
- Width 48mm
- Weight 9.0oz; 256g
- Barrel Size 1.25”
- Eye Relief 15.6mm
- Field Stop Diameter: 18.9mm
Size5 in × 4 in × 4 in
Weight2 lb
