Explore Scientific 82° Series 8.8mm - 1.25'' [ES-EPWP8288-01]
ES-EPWP8288-01
$199.99 USD
Explore Scientific: Scientific eyepiece, 8.8 mm focal length, 82 ° visible field, 31.75 mm (1.25").
The focal length of the Scientific 82 ° eyepiece of 8.8 mm predestines it rather at fairly high magnifications (113x on an optical tube of 1 meter of focal length). It is therefore suited to planetary observations (Moon, planets, Sun), double or multiple stars, as well as the observation of small planetary nebulae and the search for details in nebulae and galaxies.
The eye relief of the 8.8 mm is 15.6 mm: this means that the image remains comfortable up to 15.6 mm above the lens, to take full advantage of the field offered by the lens, ocular. This is an important detail for the viewer wearing eyeglasses, which will keep them on the nose.
Finally, it fits into the 1.25 "(31.75 mm) eyepiece holders. The inside of the sink is threaded in M28.5 x 0.6 mm to accommodate filters with 31.75 mm (1.25"), Such as interference filters of type OIII, UHC, H-Beta, etc., which serve to enhance the contrast on many nebulae.
About Explore Scientific 82° Series 8.8mm - 1.25'' [ES-EPWP8288-01]
  • Description    8.8mm 82° Series Argon-Purged Waterproof Eyepiece
  • Item Number    EPWP8288-01
  • Focal Length    8.8mm
  • Length    85mm
  • Width    48mm
  • Weight    8.9oz; 255g
  • Barrel Size    1.25”
  • Eye Relief    15.6mm
  • Field Stop Diameter:    12.4mm
    5 in × 4 in × 4 in
    2 lb
