Explore Scientific 82° Series 6.7mm- 1.25'' [ES-EPWP8267-01]
ES-EPWP8267-01
$199.99 USD
Explore Scientific: Scientific eyepiece, focal length of 6.7 mm, apparent field of 82 °, barrel size 31.75 mm (1.25").
In recent years, Explore Scientific eyepieces have forged a solid reputation in terms of quality , And competitive rates. Watching in an eyepiece Explore is a pleasant and easy experience, the picture is beautiful from the first glance.
The focal length of the Explore Scientific 82 ° eyepiece of 6.7 mm predestines it at high magnifications (149x on an optical tube of 1 meter of focal length). It is therefore suited to planetary observations (Moon, planets, Sun), double or multiple stars, as well as the observation of small planetary nebulae and the search for details in nebulae and galaxies.
The eye relief of the 6.7 mm is 15.7 mm: this means that the image remains comfortable up to a distance of 15.7 mm above the lens, to take full advantage of the field offered by the lens. ocular. This is an important detail for the viewer wearing eyeglasses, which will keep them on the nose.
Finally, it fits into the 1.25 "(31.75 mm) eyepiece holders. The inside of the sink is threaded in M28.5 x 0.6 mm to accommodate filters with 31.75 mm (1.25" ), Such as interference filters of type OIII, UHC, H-Beta, etc., which serve to enhance the contrast on many nebulae.
About Explore Scientific 82° Series 6.7mm- 1.25'' [ES-EPWP8267-01]
  • Description    6.7mm 82° Series Argon-Purged Waterproof Eyepiece
  • Item Number    EPWP8267-01
  • Focal Length    6.7mm
  • Length    90mm
  • Width    43mm
  • Weight    8.0oz; 228g
  • Barrel Size    1.25”
  • Eye Relief    15.7mm
  • Field Stop Diameter:    9.5mm
    5 in × 4 in × 4 in
    2 lb
