Explore Scientific 68° Series 24mm - 1.25'' [ES-EPWP6824-01]
ES-EPWP6824-01
$189.99 USD
2 in stock IN STOCK, usually ships within 48h or less directly from our Canadian warehouse
Explore Scientific: Explore Scientific Eyepiece, 24 mm focal length, 68 ° visible field, 31.75 mm (1.25 ").
This eyepiece offers an apparent wide field of 68 °, high level optical quality, surprising light transmission and correctly corrected field planarity ...
The Explore Scientific 68 ° eyepiece range is well suited for the amateur astronomer looking for optical quality while remaining within a moderate budget. It is an excellent compromise for owners of telescopes with diameters between 150 mm and 300 mm. Observing the Orion nebula in these eyepieces through a Dobson telescope of 200 mm reserves very pleasant surprises.
Each eyepiece of the series 68 ° is sealed and filled with an inert gas, argon. This process prevents the formation of condensation inside the eyepiece and prevents the entry of dust to maximize the lifetime of the internal coatings.
All eyepieces in the 68 ° series are fully multilayered and the edges are blackened to produce maximum contrast.
The Explore Scientific 68 ° delivers sharp, contrasting images. The apparent field of 68 ° is relatively wide, allowing you to keep a celestial object observed in a non-motorized instrument long enough in sight.
The focal length of the Scientific 68 ° eyepiece of 24 mm predestines it at low magnifications (42x on an optical tube of 1 meter of focal length), making it very suitable for the observation in detail of large nebulae or galaxies, clusters Galaxies or comets, while benefiting from a very wide field of vision.
The 24 mm eye relief is 18.4 mm, which means that the image remains comfortable up to a distance of 18.4 mm above the lens, ocular. This is an important detail for the viewer wearing eyeglasses, which will keep them on the nose.
Finally, it fits into the 1.25 "(31.75 mm) eyepiece holders. The inside of the sink is threaded in M28.5 x 0.6 mm to accommodate filters with 31.75 mm (1.25" ), Such as interference filters of type OIII, UHC, H-Beta, etc., which serve to enhance the contrast on many nebulae.
About Explore Scientific 68° Series 24mm - 1.25'' [ES-EPWP6824-01]
  • Description    24mm 68° Series Argon-Purged Waterproof Eyepiece
  • Item Number    EPWP6824-01
  • Focal Length    24mm
  • Length    75.6mm
  • Width    56.2mm
  • Weight    11.6oz; 329g
  • Barrel Size    1.25”
  • Eye Relief    18.4mm
  • Field Stop Diameter:    27.2mm
    5 in × 4 in × 4 in
    2 lb
