Explore Scientific 2'' Diagonal [ES-DD02-00CF]
ES-DD02-00CF
$169.99 USD
Explore Scientific: The EXPLORE SCIENTIFIC 2″ DIAGONAL Dielectric-Coated Diagonal Mirror comes complete with 1.25-inch Adapter and dust covers. Solid construction and light weight, this first suface coated diagonal mirror reflects 99% of the light to help maintain the brightest possible image from your telescope.
The insert barrel is a double taper, so it can be smoothly inserted or withdrawn from the focuser. The wide part of the taper prevents the diagonal from accidently falling out of the focuser if the set screw loosens up. Eyepieces are secured in the diagonal with a compression ring lock on both the two-inch eyepiece holder and the 1.25-inch eyepiece holder.
Specifications:
Weight: 1 lb. Lenght: 104,8mm Widht: 60,9mm Height: 127,0mm
About Explore Scientific 2'' Diagonal [ES-DD02-00CF]
Specifications:
  • Weight: 1 lb.
  • Lenght: 104,8mm
  • Widht: 60,9mm
  • Height: 127,0mm
  • Description    ES 2" Dielectric-Coated Diagonal Mirror with 1.25" Adapter
  • Item Number    DD02-00CF
  • Weight    1.0lb; .45kg
  • Length    104.8mm
  • Width    60.9mm
  • Height    127.0mm
    7 in × 7 in × 6 in
    2 lb
