Explore Scientific 208mm Carbon Fiber [ES-N208CF]
ES-N208CF
$599.99 USD
Explore Scientific: The EXPLORE SCIENTIFIC 208MM CARBON FIBER allows this larger primary mirror, with faster aperture ratio compared to the usual 8″ f/4 for deeper shots with the same exposure time. The completely redesigned “click-fix” secondary mirror mechanism ensures easy and optimal collimation. The large 80mm secondary mirror offers optimal field illumination. This amazing scope includes a high quality 2″ focuser with 10:1 reduction; cradle rings with vixen style dovetail rail and carrying handle with option for mounting a camera or other accessory. The Newtonian Carbon Fiber scope also stands out with 1/4 lighter weight compared to the aluminum Bresser version and a virtually nonexistent focus drift during long exposures.
Specifications:
Primary Mirror Diameter: 208mm Secondary Mirror Diameter (M.A.): 80mm Focal Length :812mm Focal Ratio: f/3.9 Resolving Power: .6 arc seconds Optical Tube Assembly Weight: 19.6lb Dovetail: Vixen
About Explore Scientific 208mm Carbon Fiber [ES-N208CF]
Specifications:
  • Primary Mirror Diameter: 208mm
  • Secondary Mirror Diameter (M.A.): 80mm
  • Focal Length :812mm
  • Focal Ratio: f/3.9
  • Resolving Power: .6 arc seconds
  • Optical Tube Assembly Weight: 19.6lb
  • Dovetail: Vixen
  • Description    208mm Newtonian f/3.9 with Carbon Fiber Tube
  • Item Number    N208CF
  • Primary Mirror Diameter    208mm
  • Secondary Mirror Diameter (M.A.)    80mm
  • Focal Length    812mm
  • Focal Ratio    f/3.9
  • Resolving Power    .6 arc seconds
  • Optical Tube Assembly Weight    18.3lb
  • Dovetail    Vixen
    36 in × 16 in × 16 in
    34 lb
