Cooled CDS-600D II Pro color DSLR (Hoya Clear filter) [CDS-600D-II-PRO]
CDS-600D-II-PRO
$1,830.00 USD
CentralDS:At last we launched the upgraded CDS-600D with new design as the name of CDS-600D II and CDS-600D II Pro with more powerful cooling.
Drop-In filter holder for 2 inch astronomical filters is equipped in these cameras.
CDS-600D is designed to be a remote controlled camera without LCD screen with only basic function of camera but it can dramatically enhance the image quality in low light photography.
After 600D, Until now CANON continued to open new DSLR models named 650D, 700D.
650D and 700D are also having 18 Mega pixels and this are same to 600D’s. The major improvement of these latest models were made at the area of AF or Movie function or user interfaces. Long ago we deeply tested 650D and 700D compared to 600D and we found a astonishing facts that the 600D’s image quality is more stable and good with lower noise than that of 650D or 700D in case of low light, high iso, long time exposure photography.
We guess that the modified image processing algolism caused by hybrid AF sensor pixels on CMOS produce bad results of low light imaging.
After 650D, 700D launched, the price of 600D became more good and CANON did not discontinue 600D and we can easily buy it at the market until now.
We stopped the 650D, 700D project and started the work for CDS-600D upgrade.
The main design concept of CDS-600D II is based on that of CDS-5D. 3parts configuration(= Body, Adapter, Cooler) and Temperature controller were applied. The shape of CDS-600D II became so similar to that of CDS-5D but smaller.
The module parts are compatible with CDS-5D and economical and consistent quality control and improvement will be possible.
There was a big loss and it’s mechanical shutter in front of imager sensor.
To equip the Drop-In filter system, there is needed the space between lens mount and Image sensor. We removed the shutter blades and moved the shutter body to the side of CMOS. And camera body was became a low profile body as that of CDS-5D and the space for drop-in filter holder was prepared. CDS-600D II was became [B shutter only ] camera like CDS-5D. But using USB connection to PC and control software(EOS Utility, BackyardEOS, etc.,) you can set the exposure time by 1 second.
In CDS-600D, we provided [movie mode/Manual Exposure Mode] selection Switch. We found that most users do not take [Movie] using CDS-600D camera. And when we  design CDS-600D II, we disabled [movie mode] and made this camera to only still frame camera for astro imaging.
Two types of cooler concept are in CDS-600D II,
One is a traditional full size cooler module like that of CDS-5D’s and another is simple and thin cooler module.
CDS-600DII with the former style cooler is [CDS-600D II Pro] and the latter style is [CDS-600D II].
[CDS-600D II] is having lighter, smaller body shape with [Ambient -23°C  (+2~-2°C)] cooling performance.[CDS-600D II Pro] body is more heavy and bigger but it’s cooling performance is more higher and reach to[Ambient temperature -33°C  (+2~-2°C)].
Two models are use 1 stage 36Watt high efficiency TEC cooler and the best rated cooling fan  of Moctua company, Austria and we’ve completed the high power and extremely silent cooling system.
About Cooled CDS-600D II Pro color DSLR (Hoya Clear filter) [CDS-600D-II-PRO]
  • IMAGE SENSOR    22.3 x 14.9mm (18 megapixels)
  • IMAGE PROCESSOR    DIGIC4
  • IMAGE FORMAT    RAW(CR2 14bit), JPEG
  • MOVIE         Do not support
  • INTERFACE      USB 2.0
  • SHUTTER SPEED      B shutter only
  • EXPOSURE MODE     Manual( Bulb shutter only)
  • POWER     12V DC 3.6Amps Max
  • MOUNT    Wide T, T, 3″ Adapter,2″ Nosepiece, EOS adapter
  • TEMPERATURE CONTROL       Yes
  • ( PID Temperature Controller)
  • COOLING     CDS-600D II : Ambient Temperature -23℃
  • CDS-600D II Pro: Ambient Temperature -33℃
  • SOFTWARE    Backyard EOS, EOS utility
  • OS    Windows XP, VISTA, Window7(32bit,64bit)
  • REMOVED FUNCTIONS       Mirror box,view finder,Auto focus,LCD,control
  • buttons,Flash strob,Li-ion Battery, videoout,
  • HDMI out, microphone,Mode Dial, Shutter
  • DIMENSION    CDS-600D II:       145x140x90mm
  • CDS-600D II Pro: 145x140x118mm
  • WEIGHT    1,050g / 1,550g (CDS-600D II Pro)
