BackyardNIKON 1.0 Classic Edition [OTL-BYN-C]
OTL-BYN-C
(0 reviews)
$35.00 USD
About BackyardNIKON 1.0 Classic Edition [OTL-BYN-C]
Supported Cameras
BackyardNIKON supports over 25 Nikon DSLR models!
When you see (serial) for a particular function, it means a serial cable is needed to access that function in addition to the regular USB cable for all other functions. BackyardNIKON has been tested with Shoestring Astronomy DSUSB serial cables.
1V3 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D3 Not supported
D3S Yes Yes (serial) No Vista, W7, W8, W10 (32/64 bits) (Vista SP2 compatibility mode) Yes
D3X Not supported
D4 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D4S Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D5 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D40 No Yes (serial/ir) No Vista, W7, W8, W10 (32/64 bits) (Vista SP2 compatibility mode) Yes
D40X No Yes (serial/ir) No Vista, W7, W8, W10 (32/64 bits) (Vista SP2 compatibility mode) Yes
D50 Not supported
D60 No Yes (serial/ir) No Vista, W7, W8, W10 (32/64 bits) (Vista SP2 compatibility mode) Yes
D70 Not supported
D80 No Yes (serial/ir) No Vista, W7, W8, W10 (32/64 bits) (Vista SP2 compatibility mode) Yes
D90 Yes Yes (serial) No Vista, W7, W8, W10 (32/64 bits) Yes
D200 No Yes (serial) No Vista, W7, W8, W10 (32/64 bits) (Vista SP2 compatibility mode) Yes
D300 Yes Yes (serial) No Vista, W7, W8, W10 (32/64 bits) Yes
D300S Yes Yes (serial) No Vista, W7, W8, W10 (32/64 bits) Yes
D500 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D600 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D610 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D700 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D750 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D800 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D810 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D810a Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D850 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D3000 Not supported
D3100 Not supported
D3200 Not supported
D3300 Not supported
D3400 Not supported
D3500 Not supported
D5000 Yes Yes (serial) No Vista, W7, W8, W10 (32/64 bits) Yes
D5100 Yes Yes (serial) No Vista, W7, W8, W10 (32/64 bits) Yes
D5200 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D5300 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D5500 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D5600 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D7000 Yes Yes (serial) No Vista, W7, W8, W10 (32/64 bits) Yes
D7100 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
D7200 Yes Yes (usb) No Vista, W7, W8, W10 (32/64 bits) Yes
Compare Editions
BackyardNIKON upgrade instructions
If you have purchased BackyardNIKON in the past chances are you can upgrade to the most latest version/edition for free.
You need an account first!
I already have BackyardNIKON 1.0 or 2.0 and I just want the latest release. What do I do?
Upgrading from BackyardNIKON 1.0.x or 2.0.x to the latest 2.0.x is FREE.
What do I need to do?
If you currently own BackyardNIKON 1.0.x or or 2.0.x and simply wish to get the latest version of that same edition there is no special upgrade path; simply download the latest version, install, use the same key, and enjoy!
How-to upgrade from BackyardNIKON 1.0 or 2.0 Classic Edition to BackyardNIKON 2.0.x Premium Edition?
Upgrading from BackyardNIKON 1.0.x or 2.0.x Classic Edition to BackyardNIKON 2.0.x Premium Edition is $20 USD.
What do I do?
  2. Go to our store and add BackyardNIKON Premium Edition in your cart and proceed to checkout.
  3. Enter coupon code 'BYN-UPG-PREMIUM' on the checkout page.
  7. Download, install, enjoy!
BackyardEOS, BackyardNIKON ('Software') and all of its documentation Copyright 2010-2018 O'Telescope Corporation
4. Non-Canadian end users are strictly prohibited from using the 'Software' in Canada. In return you will not be charged Canadian sales tax. If you do not agree you must (a) pay sales tax on the 'Software' or (b) immediately stop using the 'Software', uninstall, and remove all copies.
LIMITED WARRANTY
5. We warrant that the software will provide the features and functions generally described in the product specification on our website when you purchased it and in the product documentation. Media, on which the Software is furnished, if any, will be free from defects in materials and workmanship.
6. We have taken all reasonable steps to keep the software free of viruses, spyware, 'back door' entrances, or any other harmful code. We will not track or collect any information about you, your data, or your use of the software except as you specifically authorize. We will not intentionally deprive you of your ability to use any features of the software or access to your data.
7. We do not warrant that the software or your ability to use it will be uninterrupted or error-free. To the extent permitted by applicable law, we disclaim any implied warranty of merchantability or fitness for a particular purpose.
LIMITATIONS ON LIABILITY
8. Your exclusive remedy under the above limited warranty shall be, at our option, either a full refund of the purchase price or correction of the defective software or media. To the fullest extent permitted by applicable law, we disclaim all liability for indirect or consequential damages that arise under this license agreement. Nothing in this agreement limits our liability to you in the event of death or personal injury resulting from gross negligence, fraud, or knowing misrepresentation on our part.
GENERAL PROVISIONS
9. If any part of this agreement is found to be invalid or unenforceable, the remaining terms will stay in effect. This agreement does not prejudice the statutory rights of any party dealing as a consumer.
10. This License Agreement is governed by the laws of Canada and other countries where applicable.
11. This License Agreement replaces and supersedes all prior negotiations, dealings, agreements between Licensor and Licensee regarding the software, and is retroactive to the date the 'Software' was acquired.
