G1-1200C color CCD camera with Sony ICX445AQA CCD [MVI-G1-1200C]
MVI-G1-1200C
$599.75 USD
Moravian Instruments: 1/3'' progressive scan CCD 1280 x 960 pixels, CS-thread lens adapter, CS to 1.25'' lens adapter
About G1-1200C color CCD camera with Sony ICX445AQA CCD [MVI-G1-1200C]
Model CCD chip CCD architecture Color filters Resolution Pixel size Imaging area Download time
G1-0300 ICX424AL progressive none 656 × 494 7.4 × 7.4 μm 4.9 × 3.7 mm ~ 0.05 s
G1-0300C ICX424AQ progressive RGBG (Bayer) 656 × 494 7.4 × 7.4 μm 4.9 × 3.7 mm ~ 0.05 s
G1-0301 ICX414AL progressive žádné 656 × 494 9.9 × 9.9 μm 6.5 × 4.9 mm ~ 0.05 s
G1-0301C ICX414AQ progressive RGBG (Bayer) 656 × 494 9.9 × 9.9 μm 6.5 × 4.9 mm ~ 0.05 s
G1-0800 ICX204AL progressive none 1032 × 778 4.65 × 4.65 μm 4.8 × 3.6 mm ~ 0.1 s
G1-0800C ICX204AK progressive RGBG (Bayer) 1032 × 778 4.65 × 4.65 μm 4.8 × 3.6 mm ~ 0.1 s
G1-1200 ICX445ALA progressive none 1296 × 966 3.75 × 3.75 μm 4.9 × 3.6 mm ~ 0.15 s
G1-1200C ICX445AQA progressive RGBG (Bayer) 1296 × 966 3.75 × 3.75 μm 4.9 × 3.6 mm ~ 0.15 s
G1-1400 ICX285AL progressive no 1392 × 1040 6.45 × 6.45 μm 9.0 × 6.7 mm ~ 0.18 s
G1-1400C ICX285AQ progressive RGBG (Bayer) 1392 × 1040 6.45 × 6.45 μm 9.0 × 6.7 mm ~ 0.18 s
G1-2000 ICX274AK progressive none 1628 × 1236 4.4 × 4.4 μm 7.2 × 5.4 mm ~ 0.25 s
G1-2000C ICX274AQ progressive RGBG (Bayer) 1628 × 1236 4.4 × 4.4 μm 7.2 × 5.4 mm ~ 0.25 s
