G1-0300 monochrome CCD camera with Sony ICX424AL CCD [MVI-G1-0300]
G0/G1 cameras also provide very fast readout—pixel digitization speed reaches 8 MPx/s in fast read mode.
About G1-0300 monochrome CCD camera with Sony ICX424AL CCD [MVI-G1-0300]
Moravian Instruments: 1/3'' progressive scan CCD 640 x 480 pixels, CS-thread lens adapter, CS to 1.25'' lens adapter
Model | CCD chip | CCD architecture | Color filters | Resolution | Pixel size | Imaging area | Download time |
G1-0300 | ICX424AL | progressive | none | 656 × 494 | 7.4 × 7.4 μm | 4.9 × 3.7 mm | ~ 0.05 s |
G1-0300C | ICX424AQ | progressive | RGBG (Bayer) | 656 × 494 | 7.4 × 7.4 μm | 4.9 × 3.7 mm | ~ 0.05 s |
G1-0301 | ICX414AL | progressive | žádné | 656 × 494 | 9.9 × 9.9 μm | 6.5 × 4.9 mm | ~ 0.05 s |
G1-0301C | ICX414AQ | progressive | RGBG (Bayer) | 656 × 494 | 9.9 × 9.9 μm | 6.5 × 4.9 mm | ~ 0.05 s |
G1-0800 | ICX204AL | progressive | none | 1032 × 778 | 4.65 × 4.65 μm | 4.8 × 3.6 mm | ~ 0.1 s |
G1-0800C | ICX204AK | progressive | RGBG (Bayer) | 1032 × 778 | 4.65 × 4.65 μm | 4.8 × 3.6 mm | ~ 0.1 s |
G1-1200 | ICX445ALA | progressive | none | 1296 × 966 | 3.75 × 3.75 μm | 4.9 × 3.6 mm | ~ 0.15 s |
G1-1200C | ICX445AQA | progressive | RGBG (Bayer) | 1296 × 966 | 3.75 × 3.75 μm | 4.9 × 3.6 mm | ~ 0.15 s |
G1-1400 | ICX285AL | progressive | no | 1392 × 1040 | 6.45 × 6.45 μm | 9.0 × 6.7 mm | ~ 0.18 s |
G1-1400C | ICX285AQ | progressive | RGBG (Bayer) | 1392 × 1040 | 6.45 × 6.45 μm | 9.0 × 6.7 mm | ~ 0.18 s |
G1-2000 | ICX274AK | progressive | none | 1628 × 1236 | 4.4 × 4.4 μm | 7.2 × 5.4 mm | ~ 0.25 s |
G1-2000C | ICX274AQ | progressive | RGBG (Bayer) | 1628 × 1236 | 4.4 × 4.4 μm | 7.2 × 5.4 mm | ~ 0.25 s |
