G0-2000 monochrome CCD camera with Sony ICX274AL CCD [MVI-G0-2000]
MVI-G0-2000
$681.80 USD
Moravian Instruments: 1/2'' progressive scan CCD 1600 x 1200 pixels, 1.25'' focuser adapter
About G0-2000 monochrome CCD camera with Sony ICX274AL CCD [MVI-G0-2000]
Model CCD ABG Color mask Resolution Pixel size Chip area
G0-0300 ICX424AL yes none 656 × 494 7.4 × 7.4 μm 4.9 × 3.7 mm
G0-0300C ICX424AQ yes RGBG (Bayer) 656 × 494 7.4 × 7.4 μm 4.9 × 3.7 mm
G0-0800 ICX204AL yes none 1032 × 778 4.65 × 4.65 μm 4.8 × 3.6 mm
G0-0800C ICX204AK yes RGBG (Bayer) 1032 × 778 4.65 × 4.65 μm 4.8 × 3.6 mm
G0-2000 ICX274AL yes none 1628 × 1236 4.4 × 4.4 μm 7.2 × 5.4 mm
G0-2000C ICX274AQ yes RGBG (Bayer) 1628 × 1236 4.4 × 4.4 μm 7.2 × 5.4 mm
