External Filter Wheel for G2 cameras with 7 positions [MVI-EFW-2S-7]
About External Filter Wheel for G2 cameras with 7 positions [MVI-EFW-2S-7]
Moravian Instruments: Intended for filters in standard 2'' threaded cells or 50mm glass-only filters. Filter wheel diameter is 184 mm. Shipped with the camera only. Compatible with off axis guider. All external filter wheels has the same 17 mm thickness (the distance between the shell back side and the front plate, to which the telescope adapters are mounted). So the distance from the front plate to detector is 33.5 mm
- S series (for G2 and G3 cameras)
- diameter: is 212 mm
- weight: 0.85 kg
- Type: EFW-2XS-7
- Positions: 7
Filter type: Unmounted Ø36 mm
