Astrozap Glass solar Filter Off Axis 397mm-403mm [AZ-1562]
AZ-1562
$181.00 USD
Astrozap: Off Axis Glass Solar Filter 397mm-403mm 15-5/8 to 15-7/8 diameter, fits Meade 14 Schmidt-Cassegrain’s: 14” LX200 Series RCX 14.
About Astrozap Glass solar Filter Off Axis 397mm-403mm [AZ-1562]
