Astrozap Glass solar Filter Off Axis 391mm-397mm [AZ-1561]
About Astrozap Glass solar Filter Off Axis 391mm-397mm [AZ-1561]
Astrozap: Off Axis Glass Solar Filter 391mm-397mm 15-3/8 to 15-5/8 diameter, fits Celestron 14 SCT.
