Astrozap Glass solar Filter Off Axis 378mm-384mm [AZ-1560]
AZ-1560
$161.00 USD
Astrozap: Off Axis Glass Solar Filter 378mm-384mm 14-7/8 to 15-1/8 diameter, fits Orion 12.512” Dobs Zhumell.
About Astrozap Glass solar Filter Off Axis 378mm-384mm [AZ-1560]
