BackyardNIKON 2.0 Premium Edition [OTL-BYN-P]
BackyardNIKON is Windows only software!
BackyardNIKON is downloadable software only!
About BackyardNIKON 2.0 Premium Edition [OTL-BYN-P]
Supported Cameras
BackyardNIKON supports over 30 Nikon DSLR models!
When you see (serial) for a particular function, it means a serial cable is needed to access that function, in addition to the regular USB cable for all other functions. BackyardNIKON has been tested with Shoestring Astronomy DSUSB serial cables.
Name | Live view | Bulb | Mirror Lock | Operating System | Tested |
1V3 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D3 | Not supported | ||||
D3S | Not supported | ||||
D3X | Not supported | ||||
D4 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D4S | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D5 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D40/D40X/D50/ |
D90 | Yes | Yes (serial) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D200 | No | Yes (serial) | No | W7, W8, W10, W11 (32/64 bits) (Vista SP2 compatibility mode) | Yes |
D300 | Yes | Yes (serial) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D300S | Yes | Yes (serial) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D500 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D600 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D610 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D700 | Yes | Yes (serial) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D750 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D780 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D800 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D810 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D810a | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D850 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D3000 | Not supported | ||||
D3100 | Not supported | ||||
D3200 | Not supported | ||||
D3300 | Not supported | ||||
D3400 | Not supported | ||||
D3500 | Not supported | ||||
D5000 | Yes | Yes (serial) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D5100 | Yes | Yes (serial) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D5200 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D5300 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D5500 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D5600 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D7000 | Yes | Yes (serial) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D7100 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D7200 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
D7500 | Yes | Yes (usb) | No | W7, W8, W10, W11 (32/64 bits) | Yes |
Z6 | Yes | Yes (usb) | n/a | W7, W8, W10, W11 (32/64 bits) | Yes |
Z7 | Yes | Yes (usb) | n/a | W7, W8, W10, W11 (32/64 bits) | Yes |
Z50 | Yes | Yes (usb) | n/a | W7, W8, W10, W11 (32/64 bits) | Yes |
Compare Editions
Region | Fonctionality | Classic | Premium | Trial |
Image Capture | Configurable image capture plan | Yes | Yes | Yes |
Image Capture | Configurable image file name | Yes | Yes | Yes |
Image Capture | Camera Sensor Temperature | Yes | Yes | Yes |
Image Capture | Dithering with Push Here Dummy guiding free software | Yes | Yes | Yes |
Image Capture | Dithering with MetaGuide guiding free software | Yes | Yes | Yes |
Image Capture | Dithering with ASCOM (for those who do not guide) | Yes | Yes | Yes |
Image Capture | Create .txt file containing all EXIF meta data for each images | Yes | Yes | Yes |
Image Capture | Weather Center for ambient temperature with dew point | Yes | Yes | Yes |
Image Capture | Mask Framing | Yes | Yes | Yes |
Image Capture | Full screen presentation mode | Yes | Yes | Yes |
Frame & Focus | Full Width Half Maximum focus feedback | Yes | Yes | Yes |
Frame & Focus | Standard Deviation focus feedback | Yes | Yes | Yes |
Planetary | Ability to create .avi movies | Yes | Yes | Yes |
Planetary | In-camera 5x zoom for 1:1 pixel resolution | Yes | Yes | Yes |
Planetary | Netbook resolution support | Yes | Yes | Yes |
General | Night vision friendly | Yes | Yes | Yes |
General | Multilanguage (Catalan, Chinese - Simplified, Chinese - Thai, Dutch, English, French, German, Italian, Polish, Russian, Spanish, Turkish, Ukranian) | Yes | Yes | Yes |
Image Capture | Dual camera control | No | Yes | Yes |
Image Capture | Drag & drop image viewer | No | Yes | Yes |
Image Capture | Mark captured image quality | No | Yes | Yes |
Image Capture | Load/Save image capture plan | No | Yes | Yes |
Image Capture | Load/Save image capture plan while camera is disconnected | No | Yes | Yes |
Image Capture | Create TIFF image file (in addition to the RAW image file) | No | Yes | Yes |
Image Capture | Histogram Screen Stretch | No | Yes | Yes |
Image Capture | Mouse pointer spot histogram | No | Yes | Yes |
Frame & Focus | Half Flux Diameter focus feedback | No | Yes | Yes |
Frame & Focus | Bahtinov spikes focus feedback | No | Yes | Yes |
Drift Alignment | Complex Reticle | No | Yes | Yes |
General | AstroTortilla integration for plate solving | No | Yes | Yes |
General | ASCOM Focuser control | No | Yes | Yes |
General | ASCOM Filter Wheel control | No | Yes | Yes |
General | ASCOM Telescope 'nudge' control | No | Yes | Yes |
General | Ambient weather center logging | No | Yes | Yes |
Licensing | Time limited | No | No | 30 days |
BackyardEOS, BackyardNIKON ('Software') and all of its documentation Copyright 2010-2020 O'Telescope Corporation
This agreement was updated in December 2019 and supersedes all prior agreement.
LIMITED WARRANTY
LIMITATIONS ON LIABILITY
GENERAL PROVISIONS
