Astrozap Glass solar Filter Off Axis 340mm-346mm [AZ-1559]
AZ-1559
$151.00 USD
Astrozap: Off Axis Glass Solar Filter 340mm-346mm 13-3/8 to 13-5/8 diameter, fits Meade 12 Schmidt-Cassegrain’s: LX200 Series 12”, LX90 GPS 12”, RCX 12.
About Astrozap Glass solar Filter Off Axis 340mm-346mm [AZ-1559]
