Astrozap Glass solar Filter Off Axis 321mm-327mm [AZ-1558]
AZ-1558
$151.00 USD
Astrozap: Off Axis Glass Solar Filter 321mm-327mm 12-5/8 to 12-7/8 diameter, fits Meade Starfinder 10; Coulter 10”;Takahashi: FRC300, Mewlon 300.
About Astrozap Glass solar Filter Off Axis 321mm-327mm [AZ-1558]
