Astrozap Glass solar Filter Off Axis 295mm-302mm [AZ-1556]
AZ-1556
$121.00 USD
Astrozap: Off Axis Glass Solar Filter 295mm-302mm 11-5/8 to 11-7/8 diameter, fits all Meade 10 Schmidt-Cassegrain’s: Meade 10 LX200 Series, Meade LXD-55 10 S/ NEWT, Meade LX90 GPS 10”, RCX 10.
About Astrozap Glass solar Filter Off Axis 295mm-302mm [AZ-1556]
