Astrozap Glass solar Filter Off Axis 283mm-289mm [AZ-1555]
AZ-1555
$121.00 USD
Astrozap: Off Axis Glass Solar Filter 283mm-289mm 11-1/8 to 11-3/8 diameter, fits Celestron 10 Newt; Orion SkyWatcher 10.
About Astrozap Glass solar Filter Off Axis 283mm-289mm [AZ-1555]
