Astrozap Glass solar Filter Off Axis 257mm-264mm [AZ-1554]
About Astrozap Glass solar Filter Off Axis 257mm-264mm [AZ-1554]
Astrozap: Off Axis Glass Solar Filter 257mm-264mm 10-1/8 to 10-3/8 diameter, fits Coulter 8; Skywatcher 8” Reflector Takahashi Epsilon 180 ED.
