Astrozap Glass solar Filter Off Axis 244mm-251mm [AZ-1553]
AZ-1553
$197.95 USD
Astrozap: Off Axis Glass Solar Filter 244mm-251mm 9-5/8 to 9-7/8 diameter, fits Meade LXD-55 8 S/Newt, Meade 7 APO; Takahashi 212.
About Astrozap Glass solar Filter Off Axis 244mm-251mm [AZ-1553]
