Astrozap Glass solar Filter Off Axis 238mm-244mm [AZ-1552]
AZ-1552
$101.00 USD
Astrozap: Off Axis Glass Solar Filter 238mm-244mm 9-3/8 to 9-5/8 diameter, fits Meade Starfinder 8; Orion 8 DSE.
About Astrozap Glass solar Filter Off Axis 238mm-244mm [AZ-1552]
