Astrozap Glass solar Filter Off Axis 232mm-238mm [AZ-1551]
About Astrozap Glass solar Filter Off Axis 232mm-238mm [AZ-1551]
Astrozap: Off Axis Glass Solar Filter 232mm-238mm 9-1/8 to 9-3/8 diameter, fits Newstar 8” Dobsonians Orion: SkyQuest XT8, Atlas 8, SkyView Pro 8, Orion Sky Watcher.
