Astrozap Glass Solar Filter. 397mm-403mm. Clear aperture 343mm [AZ-1537]
This means that it allows the most light possible into the telescope because it allows the full aperture of your telescope to be viewed. The full aperture allows the best possible daytime viewing when there is minimal atmospheric turbulence. If turbulence is present a mask can be put over the end of the filter to effectively reduce the aperture.
About Astrozap Glass Solar Filter. 397mm-403mm. Clear aperture 343mm [AZ-1537]
Astrozap: Full Aperture Glass Solar Filter 397mm-403mm 15-5/8 to 15-7/8 diameter, fits Meade 14 Schmidt-Cassegrain’s: 14” LX200 Series, RCX 14. These are safe full aperture (sometimes referred as clear aperture) solar filters. T
- SKU AZ-1537
- MANUFACTURER Astrozap
- FILTER OD SIZE IN INCHES 14.1" - 16"
- WARRANTY 1 Year Warranty
- FILTER DIAMETER 16"
- FILTER FITS TELESCOPE OD RANGE OF... 397mm to 403mm
