Astrozap Glass Solar Filter. 391mm-397mm. Clear aperture 336mm [AZ-1536]
AZ-1536
$211.00 USD
Astrozap: Full Aperture Glass Solar Filter 391mm-397mm 15-3/8 to 15-5/8 diameter, fits Celestron 14” SCT.
About Astrozap Glass Solar Filter. 391mm-397mm. Clear aperture 336mm [AZ-1536]
  • SKU    AZ-1536
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    14.1" - 16"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    15.75"
  • FILTER FITS TELESCOPE OD RANGE OF...    391mm to 397mm
