Astrozap Glass Solar Filter. 264mm-270mm. Clear aperture 203mm [AZ-1529]
AZ-1529
$161.00 USD
Astrozap: Full Aperture Glass Solar Filter 264mm-270mm 10-3/8 to 10-5/8 diameter, fits Celestron 9 ¼ S-C, Celestron StarHopper 8 Dobsonian.
About Astrozap Glass Solar Filter. 264mm-270mm. Clear aperture 203mm [AZ-1529]
  • SKU    AZ-1529
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    8.1" - 11"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    10.75"
  • FILTER FITS TELESCOPE OD RANGE OF...    264mm to 270mm
