Takahashi Mewlon 210 Flexi-Heat® Flexible Heated Dew Shield Fits 244mm dia. Optical tubes [AZ-836]
AZ-836
$96.15 USD
Astrozap: Takahashi Mewlon 210 Flexi-Heat® Flexible Heated Dew Shield    Fits 244mm dia. Optical tubes
Flexi-Heat™ dew heater specs: 16 Watts @ 12 Volts, 1.40 Amps. Fits 244mm outside diameters.
The Astrozap Flexible Heated Dew Shield uniquely combines both active and passive methods of dew fighting with the added feature of shielding the telescope from undesirable stray light.
Felt-lined to help absorb moisture and to prevent extraneous light from reaching the optics and greatly improve contrast.
Astrozap heated dew shields are made from the highest quality ABS-grade polymers.
VELCRO® Brand fasteners provide a snug fit and padded so as not to mar or scratch the telescope's finish.
They roll up easily into a convenient size for easy transportation to star parties and dark sky sites.
This product requires the use of a simple D/C adapter (AZ-719) or dual channel Astrozap Dew Controller (AZ-720) to be powered. Use of a dew controller other than Astrozap brand can cause damage and void the warranty.
12” Total Length
About Takahashi Mewlon 210 Flexi-Heat® Flexible Heated Dew Shield Fits 244mm dia. Optical tubes [AZ-836]
12” Total Length
