Astrozap Glass Solar Filter. 257mm-264mm. Clear aperture 203mm [AZ-1528]
About Astrozap Glass Solar Filter. 257mm-264mm. Clear aperture 203mm [AZ-1528]
Astrozap: Full Aperture Glass Solar Filter 257mm-264mm 10-1/8 to 10-3/8 diameter, fits Coulter 8; Skywatcher 8” Reflector Takahashi Epsilon 180 ED.
- SKU AZ-1528
- MANUFACTURER Astrozap
- FILTER OD SIZE IN INCHES 8.1" - 11"
- WARRANTY 1 Year Warranty
- FILTER DIAMETER 10.50"
- FILTER FITS TELESCOPE OD RANGE OF... 257mm to 264mm
