Astrozap Glass Solar Filter. 238mm-244mm. Clear aperture 203mm [AZ-1526]
AZ-1526
$141.09 CAD $282.18 CAD
Astrozap: Full Aperture Glass Solar Filter 238mm-244mm 9-3/8 to 9-5/8 diameter, fits Meade Starfinder 8; Orion 8 DSE.
About Astrozap Glass Solar Filter. 238mm-244mm. Clear aperture 203mm [AZ-1526]
  • SKU    AZ-1526
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    8.1" - 11"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    9.75"
  • FILTER FITS TELESCOPE OD RANGE OF...    238mm to 244mm
