Astrozap Glass Solar Filter. 232mm-238mm. Clear aperture 203mm [AZ-1525]
About Astrozap Glass Solar Filter. 232mm-238mm. Clear aperture 203mm [AZ-1525]
Astrozap: Full Aperture Glass Solar Filter 232mm-238mm 9-1/8 to 9-3/8 diameter, fits Newstar 8” Dobsonians Orion: SkyQuest XT8, Atlas 8, SkyView Pro 8, Orion Sky Watcher.
- SKU AZ-1525
- MANUFACTURER Astrozap
- FILTER OD SIZE IN INCHES 8.1" - 11"
- WARRANTY 1 Year Warranty
- FILTER DIAMETER 9.50"
- FILTER FITS TELESCOPE OD RANGE OF... 232mm to 238mm
