Astrozap Glass Solar Filter. 224mm-230mm. Clear aperture 203mm [AZ-1524]
AZ-1524
$141.00 USD
Astrozap: Full Aperture Glass Solar Filter 224mm-230mm 8-13/16 to 9-1/16 diameter, fits Celestron 8” and Meade 8” Schmidt-Cassegrain; Celestron: 8” Newtonians, C8, C8, Celestar 8, NexStar 8/8i/8SE, CPC800, CGE-800; Meade 8”: 2080, LX5, LX6, Premier, LX10, LX50, LXD-55, LXD-75, LX200, LX200R, LX200 GPS, LX90 GPS 8”; Discovery DHQ 6” Dob;Takahashi: Epsilon-180EDVixen: R200SS, VC200L, VMC200L, VMC260L.
About Astrozap Glass Solar Filter. 224mm-230mm. Clear aperture 203mm [AZ-1524]
  • SKU    AZ-1524
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    8.1" - 11"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    9.187"
  • FILTER FITS TELESCOPE OD RANGE OF...    224mm to 230mm
