Astrozap Glass Solar Filter. 203mm-210mm. Clear aperture 152mm [AZ-1522]
About Astrozap Glass Solar Filter. 203mm-210mm. Clear aperture 152mm [AZ-1522]
Astrozap: Full Aperture Glass Solar Filter 203mm-210mm 8 to 8-1/4 diameter, fits Questar 7”;Takahashi: Mewlon-180 , Orion 180 Mak.
