Astrozap Glass Solar Filter. 194mm-199mm. Clear aperture 152mm [AZ-1521]
AZ-1521
$163.52 CAD $218.02 CAD
Astrozap: Full Aperture Glass Solar Filter 194mm-199mm 7-5/8 to 7-7/8 diameter, fits Meade Starfinder; Orion: SkyView Pro 150 Mak., DSE; Intes MK 603.
About Astrozap Glass Solar Filter. 194mm-199mm. Clear aperture 152mm [AZ-1521]
  • SKU    AZ-1521
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    6.1" - 8"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    8"
  • FILTER FITS TELESCOPE OD RANGE OF...    194mm to 199mm
