Celestron NexStar 90 SLT Maksutov Flexi-Heat™ Heated Flexible Dew Shield Fits 114mm dia. Optical tubes [AZ-803-C]
The AZ-803 Flexi-Heat™ heated flexible dew shield with no notch fits the Celestron NexStar 90 SLT Maksutov telescope.
Flexi-Heat™ dew heater specs: 16 Watts @ 12 Volts, 1.40 Amps.
The Astrozap Flexible Heated Dew Shield uniquely combines both active and passive methods of dew fighting with the added feature of shielding the telescope from undesirable stray light.
Felt-lined to help absorb moisture and to prevent extraneous light from reaching the optics and greatly improve contrast.
Astrozap heated dew shields are made from the highest quality ABS-grade polymers.
VELCRO® Brand fasteners provide a snug fit and padded so as not to mar or scratch the telescope's finish.
They roll up easily into a convenient size for easy transportation to star parties and dark sky sites.
This product requires the use of a simple D/C adapter (AZ-719) or dual channel Astrozap Dew Controller (AZ-720) to be powered. Use of a dew controller other than Astrozap brand can cause damage and void the warranty.
8” Total Length
About Celestron NexStar 90 SLT Maksutov Flexi-Heat™ Heated Flexible Dew Shield Fits 114mm dia. Optical tubes [AZ-803-C]
Astrozap: Celestron NexStar 90 SLT Maksutov Flexi-Heat™ Heated Flexible Dew Shield Fits 114mm dia. Optical tubes
8” Total Length
