Astrozap Glass Solar Filter. 171mm-178mm. Clear aperture 152mm [AZ-1519]
AZ-1519
$121.00 USD
Astrozap: Full Aperture Glass Solar Filter 171mm-178mm 6-3/4 to 7 diameter, fits Celestron: C-150 CR, C-150 HD; Meade 5” APO; Orion: SpaceProbe 130, Sky Watcher 6; StellarVue: SV5 (with dew shield), SV125 (with dew shield); Takahashi FS-128; TOA-130 (with dew shield), TOA-150Intes MK 67.
About Astrozap Glass Solar Filter. 171mm-178mm. Clear aperture 152mm [AZ-1519]
SKU    AZ-1519
MANUFACTURER    Astrozap
WHITE LIGHT FILTER MATERIAL    Glass with Reflective Coating
GLASS, FILM, OR HERSCHEL?    Glass Filter
FILTER OD SIZE IN INCHES    6.1" - 8"
FULL APERTURE OR OFF-AXIS?    Full Aperture
WARRANTY    1 Year Warranty
FILTER DIAMETER    7.12"
FILTER FITS TELESCOPE OD RANGE OF...    171mm to 178mm
