Astrozap Glass Solar Filter. 149mm-156mm.Clear aperture 127mm [AZ-1517]
AZ-1517
$111.00 USD
Astrozap: Full Aperture Glass Solar Filter 149mm-156mm 5-7/8 to 6-1/8 diameter.
About Astrozap Glass Solar Filter. 149mm-156mm.Clear aperture 127mm [AZ-1517]
  • SKU    AZ-1517
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    6.1" - 8"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    6.25"
  • FILTER FITS TELESCOPE OD RANGE OF...    149mm to 156mm
